주요 콘텐츠로 건너뛰기
Sanitaire SC684 Bag Liner Replacement
필요한 것
  1. Sanitaire SC684 Bag Liner Replacement, Bag Liner: 1 단계, 이미지 1/1
    • Be sure to unplug vacuum before disassembling to prevent electric shock.
    • Unzip the red bag.
  2. Sanitaire SC684 Bag Liner Replacement: 2 단계, 이미지 1/1
    • Identify the white bag liner in the red bag.
    • Behind the white bag liner, locate the hose connecting the white bag liner and the suction hole.
  3. Sanitaire SC684 Bag Liner Replacement: 3 단계, 이미지 1/2 Sanitaire SC684 Bag Liner Replacement: 3 단계, 이미지 2/2
    • Roll down the spring coil to remove the white bag liner.
    • Remove the white bag liner from the red bag by pulling upwards firmly and it will detach from the black tube.
    • Throw away white bag liner.
  4. Sanitaire SC684 Bag Liner Replacement: 4 단계, 이미지 1/1
    • Replace white bag liner
결론
Caycie Pascual
회원 가입일: 09/26/12
1 평판
안내서 4개 작성하였습니다
Cal Poly, Team 16-58, Forte Fall 2012 Cal Poly, Team 16-58, Forte Fall 2012 회원
CPSU-FORTE-F12S16G58
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 721
