도구
No tools specified.
  1. Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay vacuum on its back
  2. Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Detach the two latches on either side of the vacuum by pulling outwards towards the wheels.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Lift off the metal plate by pulling it towards you.
    • Lift off the metal plate by pulling it towards you.
  5. Identify the belt and brush roller.
    • Identify the belt and brush roller.
    • The belt is a black circle made of rubber.
    • The brush roller has bristles and is tube shaped.
  6. Slide the belt off of the circular knob.
    • Slide the belt off of the circular knob.
  7. Pull brush roller out and detach the belt off the brush roller. Pull brush roller out and detach the belt off the brush roller.
    • Pull brush roller out and detach the belt off the brush roller.
결론
Caycie Pascual
회원 가입일: 2012년 09월 26일
1 평판
안내서 5개 작성하였습니다
Cal Poly, Team 16-58, Forte Fall 2012 Cal Poly, Team 16-58, Forte Fall 2012 회원
CPSU-FORTE-F12S16G58
5 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 839
