주요 콘텐츠로 건너뛰기
Sanitaire SC684 front wheel replacement
필요한 것
  1. Sanitaire SC684 front wheel replacement, Front Wheels: 1 단계, 이미지 1/1
    • Be sure to unplug the vacuum before disassembling it to prevent electric shock.
    • Lay the vacuum on its side.
    • Using a Phillips #1 screwdriver, unscrew the screws located behind the front wheels on the underside of the vacuum.
  2. Sanitaire SC684 front wheel replacement: 2 단계, 이미지 1/2 Sanitaire SC684 front wheel replacement: 2 단계, 이미지 2/2
    • Stand the vacuum upright, unscrew the single screw located on the center dial using a Torx T20 screwdriver and remove the dial form the vacuum body.
  3. Sanitaire SC684 front wheel replacement: 3 단계, 이미지 1/1
    • Lift the top cover off of the vacuum.
  4. Sanitaire SC684 front wheel replacement: 4 단계, 이미지 1/1
    • Identify the two gray metal plates at the front of the vacuum.
    • Using the T20 Torx screwdriver, remove the four screws on the smaller gray plate holding the larger gray metal plates.
  5. Sanitaire SC684 front wheel replacement: 5 단계, 이미지 1/2 Sanitaire SC684 front wheel replacement: 5 단계, 이미지 2/2
    • Remove the small metal plate with the black bolt in the center and the larger gray plate from both sides.
  6. Sanitaire SC684 front wheel replacement: 6 단계, 이미지 1/2 Sanitaire SC684 front wheel replacement: 6 단계, 이미지 2/2
    • Pull out the silver bar that holds the two wheels to the vacuum body and detach the small spring from the vacuum body.
  7. Sanitaire SC684 front wheel replacement: 7 단계, 이미지 1/2 Sanitaire SC684 front wheel replacement: 7 단계, 이미지 2/2
    • Remove the wheel from the side with the spring by pulling it off the axel and slide off the spring, as it will be needed for the replacement front wheels.
결론
Caycie Pascual
회원 가입일: 09/26/12
1 평판
안내서 4개 작성하였습니다
Cal Poly, Team 16-58, Forte Fall 2012 Cal Poly, Team 16-58, Forte Fall 2012 회원
CPSU-FORTE-F12S16G58
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 1,030
