주요 콘텐츠로 건너뛰기
Sansa e260R Memory Board Replacement
필요한 것
  1. Sansa e260R Memory Board Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Memory Board Replacement: 2 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Memory Board Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Memory Board Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Memory Board Replacement, Front Panel: 5 단계, 이미지 1개 중 1개
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Memory Board Replacement: 6 단계, 이미지 1개 중 1개
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Memory Board Replacement: 7 단계, 이미지 2개 중 1개 Sansa e260R Memory Board Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the front cover away from the rest of the device.
  8. Sansa e260R Memory Board Replacement, Memory Board: 8 단계, 이미지 2개 중 1개 Sansa e260R Memory Board Replacement, Memory Board: 8 단계, 이미지 2개 중 2개
    • Near the charging port, pull the case away from the motherboard to create clearance to remove the motherboard.
    • Use the spudger to push the motherboard in and pop the metal edge of the charging port up and inside the plastic case.
  9. Sansa e260R Memory Board Replacement: 9 단계, 이미지 1개 중 1개
    • Pull the bottom of the motherboard up and then out.
  10. Sansa e260R Memory Board Replacement: 10 단계, 이미지 1개 중 1개
    • On the back of the motherboard, there is a rectangle of rubber.
    • Peel the rectangle off slowly.
  11. Sansa e260R Memory Board Replacement: 11 단계, 이미지 1개 중 1개
    • Under the rubber rectangle, there is a strip of black tape.
    • Peel the tape off about halfway so that it is no longer attached to the memory board.
  12. Sansa e260R Memory Board Replacement: 12 단계, 이미지 1개 중 1개
    • Carefully peel the memory board away from the rest of the motherboard
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
JenniferW
회원 가입일: 01/31/12
194 평판
안내서 2개를 작성함
Cal Poly, Team 8-15, Maness Winter 2012 Cal Poly, Team 8-15, Maness Winter 2012 회원
CPSU-MANESS-W12S8G15
5 회원들
안내서 5개를 작성함
1가이드 댓글
thanks a million for this. i accidentally erased the boot partition, bought another one on eBay with a defective audio channel and switched the memory board: eureka! i’m happy listening to my tunes again!
Admin User - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 2,795
