필요한 것
Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
Near the charging port, pull the case away from the motherboard to create clearance to remove the motherboard.
Use the spudger to push the motherboard in and pop the metal edge of the charging port up and inside the plastic case.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
thanks a million for this. i accidentally erased the boot partition, bought another one on eBay with a defective audio channel and switched the memory board: eureka! i’m happy listening to my tunes again!
Admin User - 답글
