1. Before disassembling the device, make sure it is powered off.
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Using a plastic opening tool, lift the metal backing from the front of the device.
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Pull the rear panel off of the Sansa e260R.
    • Pull the rear panel off of the Sansa e260R.
  4. Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  6. Remove the four 1.5mm screws on the inner casing of the device.
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  7. Flip the device so that the front is facing you.
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  8. Pull the front cover away from the rest of the device. Pull the front cover away from the rest of the device.
    • Pull the front cover away from the rest of the device.
  9. Gently pry the bottom of the black button to remove it from the device. Gently pry the bottom of the black button to remove it from the device.
    • Gently pry the bottom of the black button to remove it from the device.
  10. There are 4 small metal hooks under the white scrolling mechanism. To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
    • There are 4 small metal hooks under the white scrolling mechanism.
    • To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
  11. Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
    • Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
결론
다른 5명이 해당 안내서를 완성하였습니다.
JenniferW
회원 가입일: 2012년 01월 31일
161 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-15, Maness Winter 2012 Cal Poly, Team 8-15, Maness Winter 2012 회원
CPSU-MANESS-W12S8G15
5 회원들
안내서 5개 작성하였습니다
Thanks very much for this guide. I used it to expose and clean my Sansa scroll wheel which is now functioning much better.
Lloyd Merriam - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 2,474
