주요 콘텐츠로 건너뛰기
Sansa e260R Scroll Wheel Replacement
필요한 것
  1. Sansa e260R Scroll Wheel Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Scroll Wheel Replacement: 2 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Scroll Wheel Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Scroll Wheel Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Scroll Wheel Replacement, Front Panel: 5 단계, 이미지 1개 중 1개
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Scroll Wheel Replacement: 6 단계, 이미지 1개 중 1개
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Scroll Wheel Replacement: 7 단계, 이미지 2개 중 1개 Sansa e260R Scroll Wheel Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the front cover away from the rest of the device.
  8. Sansa e260R Scroll Wheel Replacement, Scroll Wheel: 8 단계, 이미지 2개 중 1개 Sansa e260R Scroll Wheel Replacement, Scroll Wheel: 8 단계, 이미지 2개 중 2개
    • Gently pry the bottom of the black button to remove it from the device.
  9. Sansa e260R Scroll Wheel Replacement: 9 단계, 이미지 2개 중 1개 Sansa e260R Scroll Wheel Replacement: 9 단계, 이미지 2개 중 2개
    • There are 4 small metal hooks under the white scrolling mechanism.
    • To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
  10. Sansa e260R Scroll Wheel Replacement: 10 단계, 이미지 1개 중 1개
    • Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
JenniferW
회원 가입일: 01/31/12
194 평판
안내서 2개를 작성함
Cal Poly, Team 8-15, Maness Winter 2012 Cal Poly, Team 8-15, Maness Winter 2012 회원
CPSU-MANESS-W12S8G15
5 회원들
안내서 5개를 작성함
1가이드 댓글
Thanks very much for this guide. I used it to expose and clean my Sansa scroll wheel which is now functioning much better.
Lloyd Merriam - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 16
전체 시간: 3,505
