주요 콘텐츠로 건너뛰기
소개
This guide will illustrate for you how to replace the battery from a Sanyo Katana Eclipse X.
부품
지정된 부품이 없습니다.
  1. Press the battery release button located on the back of the phone. With the button depressed, pull down on the battery protector to remove it from the phone.
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
  3. Align the copper receptors on the back of your battery so the phone's copper receptors are touching the battery terminals.
    • Align the copper receptors on the back of your battery so the phone's copper receptors are touching the battery terminals.
    • Refer to photo illustrations.
    • Using your thumb, apply gentle pressure to the battery until it clicks into place.
  4. Take the phone’s back casing and set it over the battery.
    • Take the phone’s back casing and set it over the battery.
    • Apply gentle pressure, pushing towards the top of the phone until your hear a click.
결론
Thomas Scaggs
회원 가입일: 2012년 10월 15일
209 평판
안내서 2개 작성하였습니다
University of Maine, Team 1-3, Diaz Fall 2012 University of Maine, Team 1-3, Diaz Fall 2012 회원
UMAINE-DIAZ-F12S1G3
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 331
