주요 콘텐츠로 건너뛰기
Sanyo Katana Front Case Replacement
필요한 것
  1. Sanyo Katana Front Case Replacement, Screen Protector: 1 단계, 이미지 1/2 Sanyo Katana Front Case Replacement, Screen Protector: 1 단계, 이미지 2/2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Front Case Replacement: 2 단계, 이미지 1/2 Sanyo Katana Front Case Replacement: 2 단계, 이미지 2/2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Front Case Replacement: 3 단계, 이미지 1/2 Sanyo Katana Front Case Replacement: 3 단계, 이미지 2/2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Front Case Replacement, Front Case: 4 단계, 이미지 1/3 Sanyo Katana Front Case Replacement, Front Case: 4 단계, 이미지 2/3 Sanyo Katana Front Case Replacement, Front Case: 4 단계, 이미지 3/3
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
결론
StephenYH
회원 가입일: 03/11/13
20 평판
안내서 3개 작성하였습니다
Clemson, Team 12-1, Benson Spring 2013 Clemson, Team 12-1, Benson Spring 2013 회원
CLEM-BENSON-S13S12G1
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 248
