주요 콘텐츠로 건너뛰기
Sanyo S1414 LCD Replacement
필요한 것
  1. Sanyo S1414 LCD Replacement, LCD: 1 단계, 이미지 1/3 Sanyo S1414 LCD Replacement, LCD: 1 단계, 이미지 2/3 Sanyo S1414 LCD Replacement, LCD: 1 단계, 이미지 3/3
    • Remove the batteries and the memory card if so equipped.
    • Remove the two Phillips screws on the right.
    • Remove the four Phillips screws on the bottom.
  2. Sanyo S1414 LCD Replacement: 2 단계, 이미지 1/3 Sanyo S1414 LCD Replacement: 2 단계, 이미지 2/3 Sanyo S1414 LCD Replacement: 2 단계, 이미지 3/3
    • Remove the two screws on the left.
    • With all the screws removed, the case will split easy. No tool is required.
    • Front and back case come off at the same time. the silver midframe that houses the top buttons, remains on the camera.
  3. Sanyo S1414 LCD Replacement: 3 단계, 이미지 1/3 Sanyo S1414 LCD Replacement: 3 단계, 이미지 2/3 Sanyo S1414 LCD Replacement: 3 단계, 이미지 3/3
    • The LCD ribbon cable is folded under the holder. Do not try to remove the LCD yet. It will tear the ribbon cable.
    • Fold the LCD way from the holder. Remove the four screws that secure the holder to the logic board.
    • With the LCD holder out of the way, you can now open the ribbon cable connector. Use your fingernails to flip the white clasp away from the ribbon cable side. This will disconnect the cable. Remove the LCD and replace with the new one.
결론
다른 2명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
781,527 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
32 회원들
안내서 531개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 986
