주요 콘텐츠로 건너뛰기
Sanyo VPC S1275 Case Replacement
필요한 것
  1. Sanyo VPC S1275 Case Replacement, Battery: 1 단계, 이미지 1/1
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Sanyo VPC S1275 Case Replacement: 2 단계, 이미지 1/1
    • Remove and recycle old batteries.
  3. Sanyo VPC S1275 Case Replacement, Case: 3 단계, 이미지 1/3 Sanyo VPC S1275 Case Replacement, Case: 3 단계, 이미지 2/3 Sanyo VPC S1275 Case Replacement, Case: 3 단계, 이미지 3/3
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  4. Sanyo VPC S1275 Case Replacement: 4 단계, 이미지 1/2 Sanyo VPC S1275 Case Replacement: 4 단계, 이미지 2/2
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  5. Sanyo VPC S1275 Case Replacement: 5 단계, 이미지 1/3 Sanyo VPC S1275 Case Replacement: 5 단계, 이미지 2/3 Sanyo VPC S1275 Case Replacement: 5 단계, 이미지 3/3
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  6. Sanyo VPC S1275 Case Replacement: 6 단계, 이미지 1/1
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  7. Sanyo VPC S1275 Case Replacement: 7 단계, 이미지 1/1
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
결론
Ariana Martinez
회원 가입일: 04/15/10
50 평판
안내서 4개 작성하였습니다
Cal Poly, Team 24-24, Regan Spring 2010 Cal Poly, Team 24-24, Regan Spring 2010 회원
CPSU-REGAN-S10S24G24
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 1,976
