소개
Steps on how to remove the lens. Removal of the LCD display and the outside case is required.
부품
No parts specified.
  1. Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Slide out and open the hatch located on the bottom-right side of the camera.
    • In the revealed compartment, move the small notch and push in on the battery to remove it.
    • During reassembly, there is an arrow on the battery indicating which way it goes in.
  2. Using the Phillips #00  Screwdriver, remove the 8 screws located around the sides and bottom of the camera. Look for the screwhead with the label PH00 on the side in the kit provided. Be sure to save these screws in a secure area to ensure they are not lost.
    • Using the Phillips #00 Screwdriver, remove the 8 screws located around the sides and bottom of the camera.
    • Look for the screwhead with the label PH00 on the side in the kit provided.
    • Be sure to save these screws in a secure area to ensure they are not lost.
  3. Using the spudger, slowly pry the rear panel away from the left side. Be careful not to damage the three green cables as you remove the rear panel of the camera. Be careful not to damage the three green cables as you remove the rear panel of the camera.
    • Using the spudger, slowly pry the rear panel away from the left side.
    • Be careful not to damage the three green cables as you remove the rear panel of the camera.
  4. Using the Phillips #00 Screwdriver, remove the 8 black screws connecting the green keypad chip to the rear panel.
    • Using the Phillips #00 Screwdriver, remove the 8 black screws connecting the green keypad chip to the rear panel.
    • Do not put any excessive force on the green wires.
  5. Separate the rear panel from the rest of the camera assembly.
    • Separate the rear panel from the rest of the camera assembly.
  6. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  7. Using the Phillips #00 Screwdriver, remove the 3 screws located across the top of the camera. Using the Phillips #00 Screwdriver, remove the 3 screws located across the top of the camera.
    • Using the Phillips #00 Screwdriver, remove the 3 screws located across the top of the camera.
  8. Carefully pull off the side covers wrapped around the camera. Carefully pull off the side covers wrapped around the camera.
    • Carefully pull off the side covers wrapped around the camera.
  9. Using the spudger, gently pry the front cover of the camera off. As the front cover is fragile, it can easily break if not removed carefully. As the front cover is fragile, it can easily break if not removed carefully.
    • Using the spudger, gently pry the front cover of the camera off.
    • As the front cover is fragile, it can easily break if not removed carefully.
  10. Use caution not to damage ribbon when disconnecting. The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Use caution not to damage ribbon when disconnecting.
    • The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
    • Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
  11. The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
    • The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
  12. Flip the camera over with the lens facing up.
    • Flip the camera over with the lens facing up.
  13. Using the Phillips #00 Screwdriver, remove the two screws holding the lens in place.
    • Using the Phillips #00 Screwdriver, remove the two screws holding the lens in place.
    • Use your other hand to hold the lens in place so the lens does not fall out while removing the screws.
  14. While keeping hold of the lens, flip the entire assembly around. Using your fingers, gently push the lens out from its position in the casing.
    • While keeping hold of the lens, flip the entire assembly around.
    • Using your fingers, gently push the lens out from its position in the casing.
    • There is still a flat, golden wire connecting the lens to the motherboard.
  15. Carefully unplug the golden wire from the motherboard to remove the lens from the assembly. Carefully unplug the golden wire from the motherboard to remove the lens from the assembly.
    • Carefully unplug the golden wire from the motherboard to remove the lens from the assembly.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan Yau
회원 가입일: 2010년 04월 11일
26 평판
안내서 4개 작성하였습니다
Cal Poly, Team 27-95, Amido Spring 2010 Cal Poly, Team 27-95, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G95
4 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,857
