주요 콘텐츠로 건너뛰기
Sanyo VPC-T850 Lens Replacement
필요한 것
  1. Sanyo VPC-T850 Lens Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Lens Replacement: 2 단계, 이미지 1/1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Lens Replacement: 3 단계, 이미지 1/1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Lens Replacement: 4 단계, 이미지 1/1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
  5. Sanyo VPC-T850 Lens Replacement, Outer Casing: 5 단계, 이미지 1/3 Sanyo VPC-T850 Lens Replacement, Outer Casing: 5 단계, 이미지 2/3 Sanyo VPC-T850 Lens Replacement, Outer Casing: 5 단계, 이미지 3/3
    • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
    • Be sure to keep track of the side each screw comes from, as they come in different lengths.
  6. Sanyo VPC-T850 Lens Replacement: 6 단계, 이미지 1/2 Sanyo VPC-T850 Lens Replacement: 6 단계, 이미지 2/2
    • Orient the camera so the display is facing up.
    • Gently pull off the rear panel surrounding the display.
    • There are still three green wires connecting the panel to the rest of the camera.
    • Use your prying tool if you have difficulties removing the panel by hand.
  7. Sanyo VPC-T850 Lens Replacement: 7 단계, 이미지 1/1
    • Remove the eight black screws connecting the keypad circuit board to the rear panel.
  8. Sanyo VPC-T850 Lens Replacement: 8 단계, 이미지 1/2 Sanyo VPC-T850 Lens Replacement: 8 단계, 이미지 2/2
    • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
  9. Sanyo VPC-T850 Lens Replacement: 9 단계, 이미지 1/1
    • Flip the camera over so the lens is facing up.
    • Gently lift up the front panel to remove it from the rest of the camera.
    • Use your plastic opening tool if you have difficulties removing the panel by hand.
  10. Sanyo VPC-T850 Lens Replacement, LCD Display: 10 단계, 이미지 1/1
    • Flip the device over to where the display is located.
    • Using your plastic opening tool, lift the display out of its metal housing.
  11. Sanyo VPC-T850 Lens Replacement: 11 단계, 이미지 1/1
    • Locate the orange ribbon connecting the display to the camera.
    • Using your plastic opening tool, gently lift the black bar holding the orange ribbon to the camera.
  12. Sanyo VPC-T850 Lens Replacement: 12 단계, 이미지 1/1
    • With two fingers held firmly on the display, gently pull the orange ribbon out of the camera.
    • Pull slowly to avoid severing the orange ribbon from the display.
  13. Sanyo VPC-T850 Lens Replacement, Lens: 13 단계, 이미지 1/1
    • Orient the camera so the lens is facing up.
    • Locate and remove the two screws connecting the lens to the camera.
  14. Sanyo VPC-T850 Lens Replacement: 14 단계, 이미지 1/2 Sanyo VPC-T850 Lens Replacement: 14 단계, 이미지 2/2
    • Flip the camera back around to the other side.
    • Remove the four black screws connecting the metal display holder to the camera.
    • You do not have to remove the three screws located near the center.
    • Gently lift the display holder to reveal the underside of the lens.
  15. Sanyo VPC-T850 Lens Replacement: 15 단계, 이미지 1/3 Sanyo VPC-T850 Lens Replacement: 15 단계, 이미지 2/3 Sanyo VPC-T850 Lens Replacement: 15 단계, 이미지 3/3
    • Locate where the larger orange ribbon is plugged into the motherboard.
    • There should be a rectangular foam piece covering the part it is plugged into.
    • Using your plastic opening tool, gently lift the edge of the rectangle where the orange ribbon is connected.
  16. Sanyo VPC-T850 Lens Replacement: 16 단계, 이미지 1/1
    • With two fingers, slowly lift the lens out of its compartment.
  17. Sanyo VPC-T850 Lens Replacement: 17 단계, 이미지 1/1
    • With the lens between your thumb and index finger, pull to delicately slide the ribbons out of their connections.
    • The lens should be placed back into the compartment before attempting to reconnect the ribbons.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Robinson
회원 가입일: 10/27/15
459 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 293
