주요 콘텐츠로 건너뛰기
Sanyo VPC-X1200 LCD Screen Replacement
필요한 것
  1. Sanyo VPC-X1200 LCD Screen Replacement, Back Case: 1 단계, 이미지 1/3 Sanyo VPC-X1200 LCD Screen Replacement, Back Case: 1 단계, 이미지 2/3 Sanyo VPC-X1200 LCD Screen Replacement, Back Case: 1 단계, 이미지 3/3
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Sanyo VPC-X1200 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Gently lift up the back cover and set aside.
  3. Sanyo VPC-X1200 LCD Screen Replacement, LCD Screen: 3 단계, 이미지 1/2 Sanyo VPC-X1200 LCD Screen Replacement, LCD Screen: 3 단계, 이미지 2/2
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. Sanyo VPC-X1200 LCD Screen Replacement: 4 단계, 이미지 1/2 Sanyo VPC-X1200 LCD Screen Replacement: 4 단계, 이미지 2/2
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
결론
Anthony Giardina
회원 가입일: 04/19/10
20 평판
안내서 7개 작성하였습니다
Cal Poly, Team 7-10, Maness Spring 2010 Cal Poly, Team 7-10, Maness Spring 2010 회원
CPSU-MANESS-S10S7G10
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 5,030
