소개
This guide includes instructions for removing the main board.
The main board consists of the motherboard, plastic frame, flash capacitor, and battery tray. The motherboard cannot be separated from the main board without breaking either of the pieces. Luckily, main boards are sold as one unit.
필요한 것
Remove the five case screws with a Phillips #00 Screwdriver.
Five 3.5mm Phillips Screws
Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
There are five screws of three different sizes which need removal.
One 4.5mm screw
Four 3.5mm screws, one on the button side
One 5.5mm screws
Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
Push out pin that holds the door hinge together
Pull out the pin. Be careful to keep track of the spring and black spacer.
Set the battery door aside
