주요 콘텐츠로 건너뛰기
필요한 것
  1. Sanyo VPC-X1200 Main Board Replacement, Back Case: 1 단계, 이미지 1/3 Sanyo VPC-X1200 Main Board Replacement, Back Case: 1 단계, 이미지 2/3 Sanyo VPC-X1200 Main Board Replacement, Back Case: 1 단계, 이미지 3/3
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Sanyo VPC-X1200 Main Board Replacement: 2 단계, 이미지 1/1
    • Gently lift up the back cover and set aside.
  3. Sanyo VPC-X1200 Main Board Replacement, LCD Screen: 3 단계, 이미지 1/2 Sanyo VPC-X1200 Main Board Replacement, LCD Screen: 3 단계, 이미지 2/2
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. Sanyo VPC-X1200 Main Board Replacement: 4 단계, 이미지 1/2 Sanyo VPC-X1200 Main Board Replacement: 4 단계, 이미지 2/2
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
  5. Sanyo VPC-X1200 Main Board Replacement, Button Plate: 5 단계, 이미지 1/2 Sanyo VPC-X1200 Main Board Replacement, Button Plate: 5 단계, 이미지 2/2
    • There are five screws of three different sizes which need removal.
    • One 4.5mm screw
    • Four 3.5mm screws, one on the button side
    • One 5.5mm screws
  6. Sanyo VPC-X1200 Main Board Replacement: 6 단계, 이미지 1/2 Sanyo VPC-X1200 Main Board Replacement: 6 단계, 이미지 2/2
    • Slowly lift metal tray to the right.
    • Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
  7. Sanyo VPC-X1200 Main Board Replacement, Lens Unit: 7 단계, 이미지 1/1
    • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
    • One gate is black and another is white.
  8. Sanyo VPC-X1200 Main Board Replacement: 8 단계, 이미지 1/2 Sanyo VPC-X1200 Main Board Replacement: 8 단계, 이미지 2/2
    • Remove the three silver screws.
    • Three 5.5mm screws
  9. Sanyo VPC-X1200 Main Board Replacement: 9 단계, 이미지 1/1
    • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
  10. Sanyo VPC-X1200 Main Board Replacement, Flash Lens: 10 단계, 이미지 1/3 Sanyo VPC-X1200 Main Board Replacement, Flash Lens: 10 단계, 이미지 2/3 Sanyo VPC-X1200 Main Board Replacement, Flash Lens: 10 단계, 이미지 3/3
    • Remove 4 screws attached to the exterior silver bezel.
    • Four 3.5mm screws
  11. Sanyo VPC-X1200 Main Board Replacement: 11 단계, 이미지 1/1
    • Remove round silver bezel from the front of the camera.
  12. Sanyo VPC-X1200 Main Board Replacement: 12 단계, 이미지 1/1
    • Remove the two screws on the bottom of the front cover.
  13. Sanyo VPC-X1200 Main Board Replacement: 13 단계, 이미지 1/1
    • Remove tripod mount.
  14. Sanyo VPC-X1200 Main Board Replacement: 14 단계, 이미지 1/1
    • Carefully lift off the front cover plate of the camera.
  15. Sanyo VPC-X1200 Main Board Replacement: 15 단계, 이미지 1/1
    • Remove the flash lens using the spudger or a finger.
    • It will be attached by a piece of tape, peel the lens off of that piece of tape without removing the tape.
  16. Sanyo VPC-X1200 Main Board Replacement, Main Board: 16 단계, 이미지 1/3 Sanyo VPC-X1200 Main Board Replacement, Main Board: 16 단계, 이미지 2/3 Sanyo VPC-X1200 Main Board Replacement, Main Board: 16 단계, 이미지 3/3
    • Push out pin that holds the door hinge together
    • Pull out the pin. Be careful to keep track of the spring and black spacer.
    • Set the battery door aside
결론
Anthony Giardina
회원 가입일: 2010년 04월 19일
20 평판
안내서 7개 작성하였습니다
Cal Poly, Team 7-10, Maness Spring 2010 Cal Poly, Team 7-10, Maness Spring 2010 회원
CPSU-MANESS-S10S7G10
4 회원들
안내서 14개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 2,197
