주요 콘텐츠로 건너뛰기
Sanyo-PM 8200 Keypad Replacement
필요한 것
  1. Sanyo-PM 8200 Keypad Replacement, Power Off Phone: 1 단계, 이미지 1/1
    • Power down the phone by holding down the red "end" button.
  2. Sanyo-PM 8200 Keypad Replacement, Remove Old Battery: 2 단계, 이미지 1/1
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  3. Sanyo-PM 8200 Keypad Replacement, Back Casing: 3 단계, 이미지 1/1
    • Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
  4. Sanyo-PM 8200 Keypad Replacement: 4 단계, 이미지 1/1
    • Unscrew all four, 5mm Tri-Wing screws.
  5. Sanyo-PM 8200 Keypad Replacement: 5 단계, 이미지 1/2 Sanyo-PM 8200 Keypad Replacement: 5 단계, 이미지 2/2
    • Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
    • This step may require extra force. But too much force could break the back casing.
    • Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
  6. Sanyo-PM 8200 Keypad Replacement, Keypad: 6 단계, 이미지 1/2 Sanyo-PM 8200 Keypad Replacement, Keypad: 6 단계, 이미지 2/2
    • Remove the camera and call keys from the side of the phone where the antenna is located.
    • Remove the Readylink and volume control buttons from the other side of the phone.
  7. Sanyo-PM 8200 Keypad Replacement: 7 단계, 이미지 1/1
    • Place the plastic opening tool underneath the motherboard and gently lift up.
    • Be careful not to damage the flex cable ribbon connecting the motherboard to the device.
  8. Sanyo-PM 8200 Keypad Replacement: 8 단계, 이미지 1/3 Sanyo-PM 8200 Keypad Replacement: 8 단계, 이미지 2/3 Sanyo-PM 8200 Keypad Replacement: 8 단계, 이미지 3/3
    • Flip open the phone to reveal the keypad.
    • Place the plastic opening tool underneath the keypad and gently push the keypad towards the motherboard.
    • Remove the keypad.
결론
Cassandra Stavros
회원 가입일: 10/07/14
28 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-6, Leahy Fall 2014 USF Tampa, Team 1-6, Leahy Fall 2014 회원
USFT-LEAHY-F14S1G6
6 회원들
안내서 10개 작성하였습니다
댓글 한 개
In almost all flip phones, there’s a flex cable ribbon that connects the motherboard to the display side of the phone. It is permanently attached to the display side and plugs into the motherboard. As there are anywhere from 16 to 50 connections in the cable, I recommend being careful NOT to unplug it…aligning it for plugging it back in properly can be tricky!
Kevin Wade - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 7
전체 시간: 255
