주요 콘텐츠로 건너뛰기
Sanyo-PM 8200 Motherboard Replacement
필요한 것
  1. Sanyo-PM 8200 Motherboard Replacement, Power Off Phone: 1 단계, 이미지 1/1
    • Power down the phone by holding down the red "end" button.
  2. Sanyo-PM 8200 Motherboard Replacement, Remove Old Battery: 2 단계, 이미지 1/1
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  3. Sanyo-PM 8200 Motherboard Replacement, Back Casing: 3 단계, 이미지 1/1
    • Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
  4. Sanyo-PM 8200 Motherboard Replacement: 4 단계, 이미지 1/1
    • Unscrew all four, 5mm Tri-Wing screws.
  5. Sanyo-PM 8200 Motherboard Replacement: 5 단계, 이미지 1/2 Sanyo-PM 8200 Motherboard Replacement: 5 단계, 이미지 2/2
    • Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
    • This step may require extra force. But too much force could break the back casing.
    • Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
  6. Sanyo-PM 8200 Motherboard Replacement, Lift the Motherboard: 6 단계, 이미지 1/1
    • Gently lift up the motherboard. The keypad should now be exposed.
  7. Sanyo-PM 8200 Motherboard Replacement, Disconnect the Flex Ribbon: 7 단계, 이미지 1/1
    • Using tweezers, pull on the silver flex ribbon to disconnect it from the motherboard.
  8. Sanyo-PM 8200 Motherboard Replacement, Remove the Motherboard: 8 단계, 이미지 1/1
    • Remove the motherboard from the back of the phone.
결론
Michaella
회원 가입일: 10/07/14
101 평판
안내서 1개 작성함
USF Tampa, Team 1-6, Leahy Fall 2014 USF Tampa, Team 1-6, Leahy Fall 2014 회원
USFT-LEAHY-F14S1G6
6 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 360
