주요 콘텐츠로 건너뛰기
Satellite Pro L650 RAM Replacement
필요한 것
  1. Satellite Pro L650 RAM Replacement, Remove Battery: 1 단계, 이미지 2개 중 1개 Satellite Pro L650 RAM Replacement, Remove Battery: 1 단계, 이미지 2개 중 2개
    • (Right Side-Image 1) Pull clip outwards until it sticks
    • (Left side-Image 1/2) While pulling clip outwards, pull the battery with your other hand.
    • When re-assembling, push the battery in then engage right clip (red box)
  2. Satellite Pro L650 RAM Replacement: 2 단계, 이미지 2개 중 1개 Satellite Pro L650 RAM Replacement: 2 단계, 이미지 2개 중 2개
    • (Image 1) Unscrew the screw with a Phillips Head #00
    • (Image 2) Two clips are located at the top. Dissengage them and lift the panel.
    • A spudger can be used, but is not required.
    • When re-assembling, put the clips of the cover in first, then screw
    • Push the clips on the side out
    • Pull the RAM out of the slot
    • Only hold the RAM from the side
    • When re-assembling, make sure to put the RAM the right way up. Insert it into the slot then push down.
결론
To reassemble your device, follow these instructions in reverse order. See the Reminder boxes, located at the bottom of each step, for certain reassembly instructions.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
N Kerr
회원 가입일: 01/01/24
1,790 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 31
전체 시간: 544
