주요 콘텐츠로 건너뛰기
Satin Stitch a Tear in Your Shirt
필요한 것
  1. Satin Stitch a Tear in Your Shirt, Tear: 1 단계, 이미지 1/1
    • Examine the tear and the surrounding fabric.
    • Clip any loose threads to keep them from getting caught in the new stitching.
    • Select a coordinating color of thread and thread the sewing machine.
  2. Satin Stitch a Tear in Your Shirt: 2 단계, 이미지 1/1
    • Adjust the sewing machine to a stitch-width of two or three.
    • Stitch-width controls the sideways distance of the stitch, so if you feel you need a little more width, three is acceptable.
    • Every sewing machine is different, so refer to your sewing machine manual to find the stitch width adjustment on your machine.
    • Be sure your sewing machine is fitted with a wide-mouthed pressor foot, as opposed to one with a small round hole. When the sewing machine does a satin stitch, it will bump into the the pressor foot and break if there is not a wide enough opening.
  3. Satin Stitch a Tear in Your Shirt: 3 단계, 이미지 1/1
    • Set the sewing machine stitch length down to just above zero.
    • Stitch length controls how far forward the sewing machine advances with each stitch. Satin stitches should be very tight, which is why we want this number very close to zero.
    • Every sewing machine is different, so refer to your sewing machine manual to find the stitch length adjustment on your machine.
  4. Satin Stitch a Tear in Your Shirt: 4 단계, 이미지 1/2 Satin Stitch a Tear in Your Shirt: 4 단계, 이미지 2/2
    • If the fabric you’re repairing is gauzy or thin, you can add a small scrap of interfacing or scrap fabric on the backside of your rip or tear. Most of the time this isn’t necessary.
    • Align the fabric in the sewing machine about half an inch before the rip or tear.
    • Lower the pressor foot and begin sewing, guiding the machine over the tear.
  5. Satin Stitch a Tear in Your Shirt: 5 단계, 이미지 1/2 Satin Stitch a Tear in Your Shirt: 5 단계, 이미지 2/2
    • Sew about half an inch past the end of the slit.
    • Lift the presser foot and clip the threads to free the garment.
  6. Satin Stitch a Tear in Your Shirt: 6 단계, 이미지 1/2 Satin Stitch a Tear in Your Shirt: 6 단계, 이미지 2/2
    • Trim any extra threads.
    • Admire your handiwork.
결승점
다른 10명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,011 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,732개 작성하였습니다
댓글 3개
it repaired hannedil
Shafikahmed - 답글
Now we can save a beloved, very old Patagonia shirt
Josiah M. Daniel III - 답글
댓글 쓰기
조회 통계:
24 시간 전: 21
7일 전: 203
30일 전: 806
전체 시간: 70,277
