주요 콘텐츠로 건너뛰기
소개
This guide will walk you through the steps necessary to repair a rip or tear in your Patagonia shirt using a satin stitch—a tightly-spaced stitch that’s very wide. This guide should be used for rips and tears that aren’t on a seam. If you have a tear in the seam, see the Repairing a Torn Seam guide. This satin-stitching guide should only be used on holes that are narrow enough not to require additional fabric to patch. New to sewing? Check out our sewing glossary.
For replacement parts or further assistance, contact Patagonia Customer Service.
부품
지정된 부품이 없습니다.
  1. Examine the tear and the surrounding fabric.
    • Examine the tear and the surrounding fabric.
    • Clip any loose threads to keep them from getting caught in the new stitching.
    • Select a coordinating color of thread and thread the sewing machine.
  2. Adjust the sewing machine to a stitch-width of two or three.
    • Adjust the sewing machine to a stitch-width of two or three.
    • Stitch-width controls the sideways distance of the stitch, so if you feel you need a little more width, three is acceptable.
    • Every sewing machine is different, so refer to your sewing machine manual to find the stitch width adjustment on your machine.
    • Be sure your sewing machine is fitted with a wide-mouthed pressor foot, as opposed to one with a small round hole. When the sewing machine does a satin stitch, it will bump into the the pressor foot and break if there is not a wide enough opening.
  3. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  4. Set the sewing machine stitch length down to just above zero.
    • Set the sewing machine stitch length down to just above zero.
    • Stitch length controls how far forward the sewing machine advances with each stitch. Satin stitches should be very tight, which is why we want this number very close to zero.
    • Every sewing machine is different, so refer to your sewing machine manual to find the stitch length adjustment on your machine.
  5. If the fabric you’re repairing is gauzy or thin, you can add a small scrap of interfacing or scrap fabric on the backside of your rip or tear. Most of the time this isn’t necessary. Align the fabric in the sewing machine about half an inch before the rip or tear.
    • If the fabric you’re repairing is gauzy or thin, you can add a small scrap of interfacing or scrap fabric on the backside of your rip or tear. Most of the time this isn’t necessary.
    • Align the fabric in the sewing machine about half an inch before the rip or tear.
    • Lower the pressor foot and begin sewing, guiding the machine over the tear.
  6. Sew about half an inch past the end of the slit. Lift the presser foot and clip the threads to free the garment.
    • Sew about half an inch past the end of the slit.
    • Lift the presser foot and clip the threads to free the garment.
  7. Trim any extra threads. Admire your handiwork.
    • Trim any extra threads.
    • Admire your handiwork.
결승점
다른 7명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 2012년 03월 05일
82,087 평판
안내서 132개 작성하였습니다
iFixit iFixit 회원
Community
99 회원들
안내서 9,290개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 175
지난 30일: 617
전체 시간: 23,187
