주요 콘텐츠로 건너뛰기
Sboly Steam Espresso Machine Disassembly
필요한 것
  1. Sboly Steam Espresso Machine Disassembly, Sboly Steam Espresso Machine: 1 단계, 이미지 1개 중 1개
    • Unscrew and remove the base of the machine.
  2. Sboly Steam Espresso Machine Disassembly: 2 단계, 이미지 1개 중 1개
    • Unscrew the lid for the water opening, and take out the screws holding the metal canister in place.
  3. Sboly Steam Espresso Machine Disassembly: 3 단계, 이미지 1개 중 1개
    • Take out the screws holding the metal canister in place from the inside.
  4. Sboly Steam Espresso Machine Disassembly: 4 단계, 이미지 1개 중 1개
    • Remove the dial from the side of the machine to allow separation from the plastic hull (this step will require breaking it off with a hammer).
  5. Sboly Steam Espresso Machine Disassembly: 5 단계, 이미지 1개 중 1개
    • Remove the internal components from the outer shell (this step will require cutting the plastic tubes connecting the canister to the hull).
  6. Sboly Steam Espresso Machine Disassembly: 6 단계, 이미지 1개 중 1개
    • The switch, connected to the power source, connects to the fuses and then directly to the metal canister. From there it connects to the light indicating whether the device is being heated and to the temperature sensor, which is also connected directly to the metal canister and back to the power source.
결론
Disclaimer: Disassembly of this device requires the partial destruction of the device. To reassemble your device, follow these instructions in reverse order.
작성자
2다른 기여자 명과 함께
B Epstein-Reyes
회원 가입일: 09/10/24
183 평판
안내서 1개를 작성함
1가이드 댓글
I’m curious to know whether the straw inside the water reservoir is plastic, or silicone?
Xian - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 14
전체 시간: 126
