주요 콘텐츠로 건너뛰기
Scentsy Warmer Light Bulb Replacement
필요한 것
  1. Scentsy Warmer Light Bulb Replacement, Light Bulb Replacement: 1 단계, 이미지 1개 중 1개
    • Unplug the device's power cord from the electrical outlet.
    • If the warmer was running before you turn it off and unplug the device from its outlet, wait for the warmer to cool down (approximately 15 minutes) before you continue to the next step.
  2. Scentsy Warmer Light Bulb Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the wax warmer dish from the device.
  3. Scentsy Warmer Light Bulb Replacement: 3 단계, 이미지 2개 중 1개 Scentsy Warmer Light Bulb Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully unscrew the light bulb from its socket in a counterclockwise direction.
    • Remove the light bulb from the device.
  4. Scentsy Warmer Light Bulb Replacement: 4 단계, 이미지 2개 중 1개 Scentsy Warmer Light Bulb Replacement: 4 단계, 이미지 2개 중 2개
    • Check the wattage of the light bulb at the bottom of the device.
    • Make sure you have the correct wattage for the new light bulb in hand to replace the old one with.
  5. Scentsy Warmer Light Bulb Replacement: 5 단계, 이미지 1개 중 1개
    • Screw in the new light bulb in a clockwise direction.
  6. Scentsy Warmer Light Bulb Replacement: 6 단계, 이미지 1개 중 1개
    • Place the wax warmer dish back on top of the device.
  7. Scentsy Warmer Light Bulb Replacement: 7 단계, 이미지 1개 중 1개
    • Plug the power cord back in to the electrical outlet.
  8. Scentsy Warmer Light Bulb Replacement: 8 단계, 이미지 1개 중 1개
    • Add in a few cubes of wax.
    • For a mid size or larger warmer such as this one, use two cubes at a time, at the most. For a smaller size warmer, you only need one cube at a time. Adding more than the suggested cubes of wax to a warmer could lead to the wax not being melted all the way.
    • Turn the device on.
    • Make sure the device is powering on by observing the light indication.
결론
Once complete, the warmer should turn on and melt the wax completely, creating a good fragrance in your household.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Uyen Lawless
회원 가입일: 04/11/20
230 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 68
전체 시간: 7,252
