주요 콘텐츠로 건너뛰기
Sceptre 4K IPS 27" Monitor Button Board Replacement
필요한 것
  1. Sceptre 4K IPS 27" Monitor Button Board Replacement, Button Board: 1 단계, 이미지 1개 중 1개
    • Flip the device, and put the back of the screen towards yourself.
    • Use a soft surface to prevent damage to the screen.
  2. Sceptre 4K IPS 27" Monitor Button Board Replacement: 2 단계, 이미지 3개 중 1개 Sceptre 4K IPS 27" Monitor Button Board Replacement: 2 단계, 이미지 3개 중 2개 Sceptre 4K IPS 27" Monitor Button Board Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the seven screws using a Phillips #00 screwdriver.
    • There are four screws on the back panel and three screws on the bottom of the screen.
  3. Sceptre 4K IPS 27" Monitor Button Board Replacement: 3 단계, 이미지 2개 중 1개 Sceptre 4K IPS 27" Monitor Button Board Replacement: 3 단계, 이미지 2개 중 2개
    • Hook the tip of the screwdriver in the right corner of the back case. Try to pull up the part by your hand while inserting the tip of the screwdriver.
    • Once the tip of the screwdriver is inside the corner, gently slide down the screwdriver to detach the right side of the back case from the screen.
  4. Sceptre 4K IPS 27" Monitor Button Board Replacement: 4 단계, 이미지 3개 중 1개 Sceptre 4K IPS 27" Monitor Button Board Replacement: 4 단계, 이미지 3개 중 2개 Sceptre 4K IPS 27" Monitor Button Board Replacement: 4 단계, 이미지 3개 중 3개
    • Do the same as the previous step with the left corner to detach the left part of the back case from the screen.
    • Open the back case of the screen.
  5. Sceptre 4K IPS 27" Monitor Button Board Replacement: 5 단계, 이미지 3개 중 1개 Sceptre 4K IPS 27" Monitor Button Board Replacement: 5 단계, 이미지 3개 중 2개 Sceptre 4K IPS 27" Monitor Button Board Replacement: 5 단계, 이미지 3개 중 3개
    • In the back of the case you will see the control buttons' board.
    • Disconnect the wire connection by pulling out the wire from the board.
  6. Sceptre 4K IPS 27" Monitor Button Board Replacement: 6 단계, 이미지 3개 중 1개 Sceptre 4K IPS 27" Monitor Button Board Replacement: 6 단계, 이미지 3개 중 2개 Sceptre 4K IPS 27" Monitor Button Board Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two screws from the board using a Phillips #00 screwdriver.
    • Remove the control button board from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Moeen
회원 가입일: 01/17/24
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 20
지난 30일: 61
전체 시간: 1,042
