주요 콘텐츠로 건너뛰기
Sceptre X9 Komodo VII Board Cover Replacement
필요한 것
  1. Sceptre X9 Komodo VII Board Cover Replacement, Stand: 1 단계, 이미지 1/1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Board Cover Replacement: 2 단계, 이미지 1/1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Board Cover Replacement, Board Cover: 3 단계, 이미지 1/1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Board Cover Replacement: 4 단계, 이미지 1/3 Sceptre X9 Komodo VII Board Cover Replacement: 4 단계, 이미지 2/3 Sceptre X9 Komodo VII Board Cover Replacement: 4 단계, 이미지 3/3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Board Cover Replacement: 5 단계, 이미지 1/2 Sceptre X9 Komodo VII Board Cover Replacement: 5 단계, 이미지 2/2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ted Hsueh
회원 가입일: 09/20/12
170 평판
안내서 3개 작성하였습니다
Cal Poly, Team 16-56, Forte Fall 2012 Cal Poly, Team 16-56, Forte Fall 2012 회원
CPSU-FORTE-F12S16G56
5 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 455
