주요 콘텐츠로 건너뛰기
Sceptre X9 Komodo VII Power Supply Unit Replacement
필요한 것
  1. Sceptre X9 Komodo VII Power Supply Unit Replacement, Stand: 1 단계, 이미지 1/1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Power Supply Unit Replacement: 2 단계, 이미지 1/1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Power Supply Unit Replacement, Board Cover: 3 단계, 이미지 1/1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Power Supply Unit Replacement: 4 단계, 이미지 1/3 Sceptre X9 Komodo VII Power Supply Unit Replacement: 4 단계, 이미지 2/3 Sceptre X9 Komodo VII Power Supply Unit Replacement: 4 단계, 이미지 3/3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Power Supply Unit Replacement: 5 단계, 이미지 1/2 Sceptre X9 Komodo VII Power Supply Unit Replacement: 5 단계, 이미지 2/2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
  6. Sceptre X9 Komodo VII Power Supply Unit Replacement, Power Supply Unit: 6 단계, 이미지 1/1
    • Using a #2 Phillips screwdriver, remove the two 4.72 mm Phillips screws that hold the power adapter in place.
  7. Sceptre X9 Komodo VII Power Supply Unit Replacement: 7 단계, 이미지 1/3 Sceptre X9 Komodo VII Power Supply Unit Replacement: 7 단계, 이미지 2/3 Sceptre X9 Komodo VII Power Supply Unit Replacement: 7 단계, 이미지 3/3
    • Unplug the seven connections from the power supply unit by gently pulling on them.
  8. Sceptre X9 Komodo VII Power Supply Unit Replacement: 8 단계, 이미지 1/1
    • Using a #2 Phillips screwdriver, remove the screws and the wire that is attached to the ground.
    • Four 6 mm Phillips screws
    • One 8 mm Phillips screw
  9. Sceptre X9 Komodo VII Power Supply Unit Replacement: 9 단계, 이미지 1/2 Sceptre X9 Komodo VII Power Supply Unit Replacement: 9 단계, 이미지 2/2
    • Lift the power supply unit straight up to remove it from the back panel.
결론
Jose Carrillo
회원 가입일: 09/26/12
23 평판
안내서 1개 작성함
Cal Poly, Team 16-56, Forte Fall 2012 Cal Poly, Team 16-56, Forte Fall 2012 회원
CPSU-FORTE-F12S16G56
5 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 679
