소개
In this guide I will be showing the process of opening up this guitar to clean the contacts on the pickup selector switch. This process will apply to any guitar with a 3 way pickup toggle switch. This guide does not cover guitars with lever type switches.
필요한 것
Note the position that the selector switch is in when the guitar has intermittent or no signal.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
This worked great and exactly what I needed to fix my pickup selector switch on my Schector Omen 6. Though this should work for any pickup selector switch I'd think. I was getting intermittent issues and sometimes couldn't get the Bridge position to work at all. I was fearful I'd have to replace, so tried this first, and worked like a charm! Sounds perfect again, no new switch needed. Thank you.
