주요 콘텐츠로 건너뛰기
Schecter Demon-7 Pickup Selector Switch Replacement
필요한 것
  1. Schecter Demon-7 Pickup Selector Switch Replacement, Pickup Selector Switch: 1 단계, 이미지 1/1
    • Note the position that the selector switch is in when the guitar has intermittent or no signal.
  2. Schecter Demon-7 Pickup Selector Switch Replacement: 2 단계, 이미지 1/2 Schecter Demon-7 Pickup Selector Switch Replacement: 2 단계, 이미지 2/2
    • Remove the retaining nut that holds the pickup selector switch to the guitar.
  3. Schecter Demon-7 Pickup Selector Switch Replacement: 3 단계, 이미지 1/1
    • Place the guitar face-down on a soft and clean surface.
  4. Schecter Demon-7 Pickup Selector Switch Replacement: 4 단계, 이미지 1/2 Schecter Demon-7 Pickup Selector Switch Replacement: 4 단계, 이미지 2/2
    • If the guitar has active pickups, open the battery tray and remove the 9-volt battery.
  5. Schecter Demon-7 Pickup Selector Switch Replacement: 5 단계, 이미지 1/2 Schecter Demon-7 Pickup Selector Switch Replacement: 5 단계, 이미지 2/2
    • Remove the large plastic backing plate.
  6. Schecter Demon-7 Pickup Selector Switch Replacement: 6 단계, 이미지 1/2 Schecter Demon-7 Pickup Selector Switch Replacement: 6 단계, 이미지 2/2
    • Carefully pull the pickup selector switch out of the body of the guitar.
  7. Schecter Demon-7 Pickup Selector Switch Replacement: 7 단계, 이미지 1/1
    • Switch the pickup selector switch to the side that does not work.
    • If neither side works, then repeat the next step on each side.
  8. Schecter Demon-7 Pickup Selector Switch Replacement: 8 단계, 이미지 1/2 Schecter Demon-7 Pickup Selector Switch Replacement: 8 단계, 이미지 2/2
    • Insert the sandpaper into the switch and proceed to scuff the contacts. Be sure to flip the sandpaper and scuff each side of the contact.
  9. Schecter Demon-7 Pickup Selector Switch Replacement: 9 단계, 이미지 1/1
    • Insert the switch back into the guitar, ensure that the switch is in the correct orientation.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elias Medeiros
회원 가입일: 03/24/21
201 평판
안내서 1개 작성함
UMass Dartmouth, Team S2-G10, Riel Spring 2021 UMass Dartmouth, Team S2-G10, Riel Spring 2021 회원
UMASSD-RIEL-S21S2G10
1 회원
안내서 2개 작성하였습니다
댓글 2개
Never thought of this method. Having the same problem with my son’s Demon 7 so the only solution I could think of was to buy a new switch but I can’t find the exact one. I’ll try this trick instead. Thanks!
Seth - 답글
This worked great and exactly what I needed to fix my pickup selector switch on my Schector Omen 6. Though this should work for any pickup selector switch I'd think. I was getting intermittent issues and sometimes couldn't get the Bridge position to work at all. I was fearful I'd have to replace, so tried this first, and worked like a charm! Sounds perfect again, no new switch needed. Thank you.
Justin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 55
전체 시간: 2,295
