주요 콘텐츠로 건너뛰기
Screen Door Closer Replacement
필요한 것
  1. Screen Door Closer Replacement, Door closer: 1 단계, 이미지 1/1
    • Make sure the door is completely closed. push up from the bottom to remove the pin from the bracket that connects the barrel to the door frame and release the door closer barrel.
    • If the pin is under too much tension, open the door about an inch and slide the open clip (metal washer that keeps the screen door open) against the barrel and repeat step 1.
  2. Screen Door Closer Replacement: 2 단계, 이미지 1/1
    • After removing the pin, the closer barrel can be removed.
  3. Screen Door Closer Replacement: 3 단계, 이미지 1/1
    • Loosen the screws from the bracket on the screen door to remove the bracket.
  4. Screen Door Closer Replacement: 4 단계, 이미지 1/1
    • Loosen the screws from the door jamb bracket and remove.
  5. Screen Door Closer Replacement: 5 단계, 이미지 1/1
    • Attach the new bracket to the door jamb with provided screws.
  6. Screen Door Closer Replacement: 6 단계, 이미지 1/1
    • Slide the new clip (metal washer that was provided with the door closer) on the door closer barrel with the dented side facing inwards (as shown in photo).
  7. Screen Door Closer Replacement: 7 단계, 이미지 1/1
    • Insert the pin into the closer barrel and the jamb bracket.
  8. Screen Door Closer Replacement: 8 단계, 이미지 1/1
    • Install new bracket onto screen door. Keep screws slightly loose.
  9. Screen Door Closer Replacement: 9 단계, 이미지 1/1
    • Slip the other pin into the barrel and the bracket.
  10. Screen Door Closer Replacement: 10 단계, 이미지 1/1
    • Slide the bracket away from the barrel until there is no slack. Tighten screws on the bracket.
  11. Screen Door Closer Replacement: 11 단계, 이미지 1/1
    • Test the door and if there are any issues (i.e. door closing too fast or too slow). Make necessary adjustments to the tension screw.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Shafaq Hasan
회원 가입일: 10/26/17
122 평판
안내서 1개 작성함
DePaul University, Team S1-G10, Dush Fall 2017 DePaul University, Team S1-G10, Dush Fall 2017 회원
DPU-DUSH-F17S1G10
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 29
30일 전: 123
전체 시간: 10,081
