주요 콘텐츠로 건너뛰기
Screwless Light Switch Wall Plate Replacement
필요한 것
  1. Screwless Light Switch Wall Plate Replacement, Light Switch Wall Plate: 1 단계, 이미지 3개 중 1개 Screwless Light Switch Wall Plate Replacement, Light Switch Wall Plate: 1 단계, 이미지 3개 중 2개 Screwless Light Switch Wall Plate Replacement, Light Switch Wall Plate: 1 단계, 이미지 3개 중 3개
    • Caution: Before beginning this guide, turn the light switch off and turn off power to the switch at the circuit breaker.
    • They are usually labeled by the area of the house to which they belong.
  2. Screwless Light Switch Wall Plate Replacement: 2 단계, 이미지 3개 중 1개 Screwless Light Switch Wall Plate Replacement: 2 단계, 이미지 3개 중 2개 Screwless Light Switch Wall Plate Replacement: 2 단계, 이미지 3개 중 3개
    • Insert a prying tool into the two catches on the top of the light switch.
    • Slowly turn the prying tool or use it as a lever to push the outer plate away from the wall.
  3. Screwless Light Switch Wall Plate Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the outer layer of the faceplate.
  4. Screwless Light Switch Wall Plate Replacement: 4 단계, 이미지 2개 중 1개 Screwless Light Switch Wall Plate Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the inner part of the faceplate by unscrewing the two screws on the top and the bottom.
    • Different faceplates use different screws. Use the screwdriver that works with your screws.
  5. Screwless Light Switch Wall Plate Replacement: 5 단계, 이미지 3개 중 1개 Screwless Light Switch Wall Plate Replacement: 5 단계, 이미지 3개 중 2개 Screwless Light Switch Wall Plate Replacement: 5 단계, 이미지 3개 중 3개
    • Unbox the new faceplate.
    • Just like Step 2, remove the outer layer of the new faceplate by inserting a prying tool in the catches on its top and bottom, pushing the two layers away from each other.
  6. Screwless Light Switch Wall Plate Replacement: 6 단계, 이미지 3개 중 1개 Screwless Light Switch Wall Plate Replacement: 6 단계, 이미지 3개 중 2개 Screwless Light Switch Wall Plate Replacement: 6 단계, 이미지 3개 중 3개
    • Hold the inner layer of the faceplate against the wall.
    • Align the holes in the plate with the existing holes on the light switch or power outlet.
    • Tighten the two screws on the top and bottom.
  7. Screwless Light Switch Wall Plate Replacement: 7 단계, 이미지 3개 중 1개 Screwless Light Switch Wall Plate Replacement: 7 단계, 이미지 3개 중 2개 Screwless Light Switch Wall Plate Replacement: 7 단계, 이미지 3개 중 3개
    • Attach the outer layer of the faceplate by putting it on top of the inner layer and slightly pushing it until you hear a click sound.
결론
You can follow this guide to replace a power outlet faceplate as the procedure is essentially the same.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Davood Dehghani Firoozabadi
회원 가입일: 09/20/20
452 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 99
전체 시간: 12,433
