주요 콘텐츠로 건너뛰기
Scuf Instinct Pro D-Pad Button Cover Replacement
  1. Scuf Instinct Pro D-Pad Button Cover Replacement, Prepare your controller for disassembly: 1 단계, 이미지 1개 중 1개
    • Unplug all cables from your controller before starting.
    • Completely power off your controller.
  2. Scuf Instinct Pro D-Pad Button Cover Replacement, Remove the D-Pad cover: 2 단계, 이미지 3개 중 1개 Scuf Instinct Pro D-Pad Button Cover Replacement, Remove the D-Pad cover: 2 단계, 이미지 3개 중 2개 Scuf Instinct Pro D-Pad Button Cover Replacement, Remove the D-Pad cover: 2 단계, 이미지 3개 중 3개
    • Weak magnets secure the D-Pad cover to the controller.
    • Lift the D-Pad cover straight up to remove it.
    • During reassembly:
    • Use the alignment cutout on the bottom of the cover to orient it.
결론
Spencer Day
회원 가입일: 09/14/22
150,212 평판
안내서 995개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
1가이드 댓글
I have obviously lifted and cleaned with keyboard cleaner but when I press left on D pad I feels like it has a second engagement point, like a double like feeling
Fraser Gist - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 42
전체 시간: 641
