주요 콘텐츠로 건너뛰기
Sears Craftsman 315.109020 Blade/ Blade Cover Replacement
필요한 것
  1. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement, Blade/ Blade Cover: 1 단계, 이미지 1/2 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement, Blade/ Blade Cover: 1 단계, 이미지 2/2
    • Although this is not a difficult fix, it can definitely make a mess.
    • Lay down a dirty towel or work rag and place the saw on top of the towel.
    • Handle the saw with care and avoid placing your hands on or near the blade when possible.
  2. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: 2 단계, 이미지 1/3 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: 2 단계, 이미지 2/3 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: 2 단계, 이미지 3/3
    • Use the crescent wrench to remove the hex washer head screw and the washer.
    • Gently lift the blade up and pull it off of the internal threaded shaft.
    • If the hex washer head screw, or the entire blade spins as you turn the wrench, a quick jerk of the crescent wrench should loosen the screw.
    • Although many screws loosen in the clockwise direction, the hex washer head screw on this circular saw loosens in the counter-clockwise direction.
  3. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: 3 단계, 이미지 1/2 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: 3 단계, 이미지 2/2
    • Lift up on the blade cover until it unsnaps from the washer.
    • The blade cover will come off easier if the bulk of the cover is facing away from the saw.
결론
Blake Avant
회원 가입일: 09/29/15
218 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-4, Green Fall 2015 Cal Poly, Team 17-4, Green Fall 2015 회원
CPSU-GREEN-F15S17G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 1,044
