주요 콘텐츠로 건너뛰기
Sega CD CD Tray Replacement
필요한 것
  1. Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: 1 단계, 이미지 2개 중 1개 Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: 1 단계, 이미지 2개 중 2개
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD CD Tray Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD CD Tray Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD CD Tray Replacement: 4 단계, 이미지 1개 중 1개
    • Lift from the left side to remove the top of the case.
  5. Sega CD CD Tray Replacement: 5 단계, 이미지 1개 중 1개
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD CD Tray Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the top of the case to remove the cover.
  7. Sega CD CD Tray Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the faceplate by pulling it up, then out.
  8. Sega CD CD Tray Replacement, CD Tray: 8 단계, 이미지 2개 중 1개 Sega CD CD Tray Replacement, CD Tray: 8 단계, 이미지 2개 중 2개
    • Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
    • The three screws are shown on the diagram.
  9. Sega CD CD Tray Replacement: 9 단계, 이미지 2개 중 1개 Sega CD CD Tray Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the two screws from the plastic bar.
    • The two screws are shown pictured.
  10. Sega CD CD Tray Replacement: 10 단계, 이미지 2개 중 1개 Sega CD CD Tray Replacement: 10 단계, 이미지 2개 중 2개
    • To remove the CD tray
    • Remove the four screws with the Phillips head screwdriver.
  11. Sega CD CD Tray Replacement: 11 단계, 이미지 1개 중 1개
    • Carefully unplug the wire connected to optical reader.
  12. Sega CD CD Tray Replacement: 12 단계, 이미지 2개 중 1개 Sega CD CD Tray Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
    • The four screws are highlighted on the diagram.
    • The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
  13. Sega CD CD Tray Replacement: 13 단계, 이미지 1개 중 1개
    • Carefully remove the CD tray from circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
sskyllin
회원 가입일: 10/18/10
21 평판
안내서 2개를 작성함
Cal Poly, Team 5-14, Maness Fall 2010 Cal Poly, Team 5-14, Maness Fall 2010 회원
CPSU-MANESS-F10S5G14
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 64
전체 시간: 10,630
