주요 콘텐츠로 건너뛰기
Sega CD Plastic Housing Removal
필요한 것
  1. Sega CD Plastic Housing Removal, Sega CD Plastic Housing Removal: 1 단계, 이미지 1/2 Sega CD Plastic Housing Removal, Sega CD Plastic Housing Removal: 1 단계, 이미지 2/2
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD Plastic Housing Removal: 2 단계, 이미지 1/1
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD Plastic Housing Removal: 3 단계, 이미지 1/1
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD Plastic Housing Removal: 4 단계, 이미지 1/1
    • Lift from the left side to remove the top of the case.
  5. Sega CD Plastic Housing Removal: 5 단계, 이미지 1/1
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD Plastic Housing Removal: 6 단계, 이미지 1/1
    • Lift the top of the case to remove the cover.
  7. Sega CD Plastic Housing Removal: 7 단계, 이미지 1/1
    • Remove the faceplate by pulling it up, then out.
결론
To reassemble the device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan Kotzebue
회원 가입일: 10/07/10
271 평판
안내서 4개 작성하였습니다
Cal Poly, Team 5-14, Maness Fall 2010 Cal Poly, Team 5-14, Maness Fall 2010 회원
CPSU-MANESS-F10S5G14
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 4,934
