소개
A guide to remove the GD-ROM from the Sega Dreamcast.
부품
부품은 필요하지 않습니다.
Verify that the console is disconnected from the AC outlet before you begin.
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
댓글 쓰기
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
댓글 쓰기
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Note: Remove the expansion bay to locate the fourth screw
댓글 쓰기
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
댓글 쓰기
  • Be gentle with the white controller cable as it can be a bit fragile.
  • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
댓글 쓰기
  • Remove the four 14mm Philips #02 screws located on the controller board.
댓글 쓰기
  • Disconnect the white fan header from the controller port.
댓글 쓰기
  • Remove the controller board by lifting it up from the controller port.
댓글 쓰기
결론
다른 한 분이 해당 안내서를 완성하였습니다.
wkwong
회원 가입일: 2009년 11월 14일
414 평판
안내서 13개 작성하였습니다
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 회원
CPSU-REGAN-F09S5G1
5 회원들
안내서 23개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 38
전체 시간: 5,347
