소개
A guide to remove the expansion bay from the Sega Dreamcast.
  1. Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
결론
다른 7명이 해당 안내서를 완성하였습니다.
wkwong
회원 가입일: 2009년 11월 14일
426 평판
안내서 5개 작성하였습니다
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 회원
CPSU-REGAN-F09S5G1
5 회원들
안내서 18개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 32
전체 시간: 8,785
