이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the console over on its back.
Take note of your model number, in case replacement parts are needed.
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
Turn the console right side up.
Remove the top cover by gently lifting the upper portion of the console.
Remove the white fan header by gently pulling it away from from the controller port.
Remove the two 17.5mm Philips #00 screws from the fan bracket.
Remove the fan from the bracket.
Connect the new fan to the fan bracket using two 17.5mm Philips #00 screws.
Replace the fan bracket in the Dreamcast using two 8.5mm Philips #00 screws.
다른 4명이 해당 안내서를 완성하였습니다.
