주요 콘텐츠로 건너뛰기
Sega Dreamcast Logic Board Replacement
필요한 것
  1. Sega Dreamcast Logic Board Replacement, Expansion Bay: 1 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement, Expansion Bay: 1 단계, 이미지 2개 중 2개
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Logic Board Replacement: 2 단계, 이미지 3개 중 1개 Sega Dreamcast Logic Board Replacement: 2 단계, 이미지 3개 중 2개 Sega Dreamcast Logic Board Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Logic Board Replacement, Top Cover: 3 단계, 이미지 1개 중 1개
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Logic Board Replacement: 4 단계, 이미지 1개 중 1개
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Logic Board Replacement, Power Block (Power Supply): 5 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement, Power Block (Power Supply): 5 단계, 이미지 2개 중 2개
    • Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working.
    • Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
  6. Sega Dreamcast Logic Board Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 10mm Philips #02 screws that are fastened to the power block.
  7. Sega Dreamcast Logic Board Replacement: 7 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement: 7 단계, 이미지 2개 중 2개
    • Do not bend the male pin header between the mounted head when you remove the power supply from the chassis.
    • Remove the power board by using both hands to gently lift the power board away from the console.
  8. Sega Dreamcast Logic Board Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the clear plastic film that is tucked between the power supply and the chassis.
  9. Sega Dreamcast Logic Board Replacement, Controller Port: 9 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement, Controller Port: 9 단계, 이미지 2개 중 2개
    • Be gentle with the white controller cable as it can be a bit fragile.
    • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
  10. Sega Dreamcast Logic Board Replacement: 10 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the four 14mm Philips #02 screws located on the controller board.
  11. Sega Dreamcast Logic Board Replacement: 11 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement: 11 단계, 이미지 2개 중 2개
    • Disconnect the white fan header from the controller port.
  12. Sega Dreamcast Logic Board Replacement: 12 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the controller board by lifting it up from the controller port.
  13. Sega Dreamcast Logic Board Replacement, GD-ROM: 13 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement, GD-ROM: 13 단계, 이미지 2개 중 2개
    • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  14. Sega Dreamcast Logic Board Replacement: 14 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement: 14 단계, 이미지 2개 중 2개
    • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  15. Sega Dreamcast Logic Board Replacement: 15 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
    • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  16. Sega Dreamcast Logic Board Replacement: 16 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement: 16 단계, 이미지 2개 중 2개
    • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
    • Remove the GD-ROM by gently lifting it from its base.
  17. Sega Dreamcast Logic Board Replacement, Fan: 17 단계, 이미지 1개 중 1개
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
  18. Sega Dreamcast Logic Board Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
  19. Sega Dreamcast Logic Board Replacement: 19 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement: 19 단계, 이미지 2개 중 2개
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
  20. Sega Dreamcast Logic Board Replacement, Logic Board: 20 단계, 이미지 3개 중 1개 Sega Dreamcast Logic Board Replacement, Logic Board: 20 단계, 이미지 3개 중 2개 Sega Dreamcast Logic Board Replacement, Logic Board: 20 단계, 이미지 3개 중 3개
    • Remove the five 10mm Philips #02 screws from left side of the logic board cover.
    • Remove the three black 12mm Philips #02 screws from the right side of the logic board cover.
  21. Sega Dreamcast Logic Board Replacement: 21 단계, 이미지 3개 중 1개 Sega Dreamcast Logic Board Replacement: 21 단계, 이미지 3개 중 2개 Sega Dreamcast Logic Board Replacement: 21 단계, 이미지 3개 중 3개
    • Lift the metal cover from the console.
  22. Sega Dreamcast Logic Board Replacement: 22 단계, 이미지 2개 중 1개 Sega Dreamcast Logic Board Replacement: 22 단계, 이미지 2개 중 2개
    • Before handing the logic board, you may want to use a grounding strap to protect the device from static charge. If you do not have a grounding strip, you may ground yourself by touching a large metallic object.
    • Remove the logic board and set the logic board on an anti-static surface.
결론
다른 23명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
wkwong
회원 가입일: 11/14/09
557 평판
안내서 5개를 작성함
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 회원
CPSU-REGAN-F09S5G1
5 회원들
안내서 21개를 작성함
1가이드 댓글
helpful but my dreamcast had a different logic board and as well as fan and gd-rom so keep that in mind if u see something different in your unit
Nickolas Wilcox - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 22
지난 30일: 178
전체 시간: 26,869
