주요 콘텐츠로 건너뛰기
Sega Dreamcast Power Supply Replacement
필요한 것
  1. Sega Dreamcast Power Supply Replacement, Expansion Bay: 1 단계, 이미지 1/2 Sega Dreamcast Power Supply Replacement, Expansion Bay: 1 단계, 이미지 2/2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Power Supply Replacement: 2 단계, 이미지 1/3 Sega Dreamcast Power Supply Replacement: 2 단계, 이미지 2/3 Sega Dreamcast Power Supply Replacement: 2 단계, 이미지 3/3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Power Supply Replacement, Top Cover: 3 단계, 이미지 1/1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Power Supply Replacement: 4 단계, 이미지 1/1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Power Supply Replacement, Power Supply: 5 단계, 이미지 1/2 Sega Dreamcast Power Supply Replacement, Power Supply: 5 단계, 이미지 2/2
    • Unplug the device from the outlet. If you have just powered off the system, allow a few minutes for the capacitors to discharge before you begin working.
    • Remove the white female pin head by pinching and lifting directly up on the harness.
    • Remove the two Philips #02 screws from the board.
    • Remove the power board. Using both hands, gently lift the power board away from the console without damaging the male pin head
  6. Sega Dreamcast Power Supply Replacement: 6 단계, 이미지 1/2 Sega Dreamcast Power Supply Replacement: 6 단계, 이미지 2/2
    • Remove the unit. Carefully remove the power board from the console by lightly grasping the board by the edge and lifting directly upward.
    • Remove the two 10mm #02 Philips screws to detach the switch module from the console.
    • Purchase a replacement power board.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Jacks216
회원 가입일: 11/25/09
103 평판
안내서 1개 작성함
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 회원
CPSU-REGAN-F09S5G1
5 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 15
30일 전: 69
전체 시간: 17,156
