주요 콘텐츠로 건너뛰기
Sega Dreamcast Top Cover Replacement
필요한 것
  1. Sega Dreamcast Top Cover Replacement, Expansion Bay: 1 단계, 이미지 1/2 Sega Dreamcast Top Cover Replacement, Expansion Bay: 1 단계, 이미지 2/2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Top Cover Replacement: 2 단계, 이미지 1/3 Sega Dreamcast Top Cover Replacement: 2 단계, 이미지 2/3 Sega Dreamcast Top Cover Replacement: 2 단계, 이미지 3/3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Top Cover Replacement, Top Cover: 3 단계, 이미지 1/1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Top Cover Replacement: 4 단계, 이미지 1/1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
결론
다른 6명이 해당 안내서를 완성하였습니다.
wkwong
회원 가입일: 11/14/09
517 평판
안내서 5개 작성하였습니다
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 회원
CPSU-REGAN-F09S5G1
5 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 59
전체 시간: 11,817
