주요 콘텐츠로 건너뛰기
Sega Game Gear Screen Replacement
필요한 것
  1. Sega Game Gear Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Screen Replacement, Case: 3 단계, 이미지 1개 중 1개
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Screen Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Screen Replacement: 5 단계, 이미지 2개 중 1개 Sega Game Gear Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Screen Replacement: 6 단계, 이미지 3개 중 1개 Sega Game Gear Screen Replacement: 6 단계, 이미지 3개 중 2개 Sega Game Gear Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully unplug the 2 white-tipped connectors on the top cover.
  7. Sega Game Gear Screen Replacement, Screen: 7 단계, 이미지 1개 중 1개
    • Unscrew all the marked screws.
  8. Sega Game Gear Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Slide the logic board out from under the circular black fastener at the top-left corner of the case.
  9. Sega Game Gear Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Place the board onto a flat surface.
    • Small plastic buttons may fall off during this process, save them in a container or a place where they could be found later on.
  10. Sega Game Gear Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Unscrew the marked screws.
    • Flip the board, having its back facing up.
    • Hold onto the screen in the back, as it will flip open if not held onto.
  11. Sega Game Gear Screen Replacement: 11 단계, 이미지 2개 중 1개 Sega Game Gear Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Make sure the screen is towards the bottom, as indicated in the second picture.
  12. Sega Game Gear Screen Replacement: 12 단계, 이미지 2개 중 1개 Sega Game Gear Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Gently open the screen up.
    • The screen will not come out all the way since it is glued onto the top side.
결론
다른 15명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Lauren Thurston
회원 가입일: 04/15/10
493 평판
안내서 3개를 작성함
Cal Poly, Team 28-33, Regan Spring 2010 Cal Poly, Team 28-33, Regan Spring 2010 회원
CPSU-REGAN-S10S28G33
5 회원들
안내서 20개를 작성함
10가이드 댓글
any one know where to get a new display that wont bleed me dry?
theikester - 답글
Due to the nature a Game Gear screen attaches, a ribbon directly soldered to the mainboard, replacing it requires a soldering iron and some fairly advanced technique.
This guide, titled “Sega Game Gear Screen Replacement”, only takes us to the point you remove the ribbon. There is much work left.
Anthony Bessel - 답글
so, uh, is there a more comprehensive version somewhere?
rollin -
Thank you. I was wondering why they left this out.
Jamie O'Connell -
Does the screen get fixed at the end?
Caedmon O’Brien - 답글
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 84
지난 30일: 393
전체 시간: 70,865
