주요 콘텐츠로 건너뛰기
Sega Game Gear TV Tuner Disassembly
필요한 것
  1. Sega Game Gear TV Tuner Disassembly, Remove Housing Screws: 1 단계, 이미지 1/2 Sega Game Gear TV Tuner Disassembly, Remove Housing Screws: 1 단계, 이미지 2/2
    • Remove PH1 screw and lift up on the antenna to remove it
    • This can be done with a PH0 screwdriver but I prefer not to risk stripping the screw
    • Remove 4 PH0 screws
    • Remove 2 3.8mm gamebit screws
    • Lift rear tuner shell away from unit
  2. Sega Game Gear TV Tuner Disassembly, Remove Tint Wheel: 2 단계, 이미지 1/3 Sega Game Gear TV Tuner Disassembly, Remove Tint Wheel: 2 단계, 이미지 2/3 Sega Game Gear TV Tuner Disassembly, Remove Tint Wheel: 2 단계, 이미지 3/3
    • Before we can remove the motherboard the tint wheel needs to be removed
    • A peek on the inside reveals 2 small retaining clips. Simply apply some pressure on the clips with a needle nose tweezer
    • When reinstalling the tint wheel simply align the retaining clips with the holes and press back into place
    • Remove the motherboard from the unit
  3. Sega Game Gear TV Tuner Disassembly, Remove PCBs: 3 단계, 이미지 1/2 Sega Game Gear TV Tuner Disassembly, Remove PCBs: 3 단계, 이미지 2/2
    • When removing the front shell be careful not to lose the frequency switch button located on top of the device
    • If it makes your repair easier you can separate the two PCBs by gently pulling the ribbon out of its connector. This is a friction fit cable
  4. Sega Game Gear TV Tuner Disassembly, Remove Tuning Dial Assembly: 4 단계, 이미지 1/3 Sega Game Gear TV Tuner Disassembly, Remove Tuning Dial Assembly: 4 단계, 이미지 2/3 Sega Game Gear TV Tuner Disassembly, Remove Tuning Dial Assembly: 4 단계, 이미지 3/3
    • Flip the PCBs over with the back side facing you.
    • Remove 1 PH0 screw
    • Flip the board over again and gently pull the tuning dial assembly out of the pin header socket
결론
다른 2명이 해당 안내서를 완성하였습니다.
Navy Vet 2015
회원 가입일: 06/25/15
7,296 평판
안내서 15개 작성하였습니다
댓글 3개
does anybody know what the ribbon cables pinout is? I would love to know, so I can hook up some video-in to the tv tuner board, since my good guess is, that the upper part is just transporting or converting the signal it gets from its receiver to a mere video-in signal with LandR audio, since you can also hook up video-in to the tv tuner on the jack. and my other wild guess is, that the board the actual receiver is hooked up to splits up the signal into 8-bit chunks the game gear itself can understand. Please feel free to correct me and give more info, i NEED the pinout, since i got no tools at home to check what the ribbon cable actually is cooking.
patoschkapeter - 답글
A small washer fell out of mine when I was taking it apart. Any idea where it goes?
Kyle Mitchell - 답글
If it's very thin and small circumference it goes between the antenna and swivel. There may be 2 of them.
Navy Vet 2015 -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 29
전체 시간: 3,085
