주요 콘텐츠로 건너뛰기
Sega Genesis Motherboard Replacement
필요한 것
  1. Sega Genesis Motherboard Replacement, Outer Case: 1 단계, 이미지 1/1
    • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  2. Sega Genesis Motherboard Replacement: 2 단계, 이미지 1/1
    • Flip the Sega Genesis upright.
  3. Sega Genesis Motherboard Replacement: 3 단계, 이미지 1/1
    • Gently lift the top casing.
    • Note: the case will be connected to the main board by LED wires.
  4. Sega Genesis Motherboard Replacement: 4 단계, 이미지 1/1
    • Bend out the LED leads into vertical positions.
  5. Sega Genesis Motherboard Replacement: 5 단계, 이미지 1/1
    • Slide the LED wire apparatus off the lead pins.
    • Note: observe which color wire corresponds with which length of pin.
  6. Sega Genesis Motherboard Replacement: 6 단계, 이미지 1/1
    • Separate the main board from the outer case.
  7. Sega Genesis Motherboard Replacement, Motherboard: 7 단계, 이미지 1/1
    • Remove single black screw from the outside of the bottom cover, using a Philips screwdriver.
  8. Sega Genesis Motherboard Replacement: 8 단계, 이미지 1/1
    • Using a Philips screwdriver, remove 11 screws securing silver casing.
  9. Sega Genesis Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove silver case.
  10. Sega Genesis Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove single golden screw on motherboard using Philips screwdriver.
    • Note: Push headphone jack to the side.
  11. Sega Genesis Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove two black screws on the left and right sides of the cartridge slot.
  12. Sega Genesis Motherboard Replacement: 12 단계, 이미지 1/1
    • Remove motherboard.
  13. Sega Genesis Motherboard Replacement: 13 단계, 이미지 1/1
    • Re-install new motherboard.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Erik Bjornstrom
회원 가입일: 10/04/10
829 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-29, Regan Fall 2010 Cal Poly, Team 3-29, Regan Fall 2010 회원
CPSU-REGAN-F10S3G29
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 48
30일 전: 210
전체 시간: 32,966
