주요 콘텐츠로 건너뛰기
Sega Genesis Power LED Replacement
필요한 것
  1. Sega Genesis Power LED Replacement, Outer Case: 1 단계, 이미지 1/1
    • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  2. Sega Genesis Power LED Replacement: 2 단계, 이미지 1/1
    • Flip the Sega Genesis upright.
  3. Sega Genesis Power LED Replacement: 3 단계, 이미지 1/1
    • Gently lift the top casing.
    • Note: the case will be connected to the main board by LED wires.
  4. Sega Genesis Power LED Replacement: 4 단계, 이미지 1/1
    • Bend out the LED leads into vertical positions.
  5. Sega Genesis Power LED Replacement: 5 단계, 이미지 1/1
    • Slide the LED wire apparatus off the lead pins.
    • Note: observe which color wire corresponds with which length of pin.
  6. Sega Genesis Power LED Replacement: 6 단계, 이미지 1/1
    • Separate the main board from the outer case.
  7. Sega Genesis Power LED Replacement, Power LED: 7 단계, 이미지 1/1
    • Remove plastic "Power / On" cover by pushing tabs together.
  8. Sega Genesis Power LED Replacement: 8 단계, 이미지 1/1
    • Pull "Power / On" cover away from the console cover.
  9. Sega Genesis Power LED Replacement: 9 단계, 이미지 1/1
    • From the outside of the top cover, remove LED.
  10. Sega Genesis Power LED Replacement: 10 단계, 이미지 1/1
  11. Sega Genesis Power LED Replacement: 11 단계, 이미지 1/1
    • Re-insert "Power / On" cover until it clicks into place.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Anthony Porchia
회원 가입일: 10/11/10
437 평판
안내서 1개 작성함
Cal Poly, Team 3-29, Regan Fall 2010 Cal Poly, Team 3-29, Regan Fall 2010 회원
CPSU-REGAN-F10S3G29
4 회원들
안내서 14개 작성하였습니다
댓글 4개
My LED won't turn on when I turn on the machine though when I took it out and touched it on a battery it lit up. Did I put it back in wrong or what?
Brandon - 답글
Long leg on the LED goes to the red wire.
Short leg to the white wire. If that's not the case, you may have burned the LED or the spot doesn't work anymore.
Last attempt would be getting your +V5 from the resistor below as shown in this image.
http://i.imgur.com/TucGEXj.jpg
Thunder....16
PIero Bogani -
The model I am trying to change the led on is the 1601 HD graphics Genesis. The problem I have is there are NO simple easy press tabs to pop off the red ring. What is the correct way to remove the LED on this model? Thank you for your time.
snoopydaturd - 답글
Hey snoopy don't give up hope I made a video on how to fix your problem check out this video
https://youtu.be/HJPyhfy56a0
thebigtoe_98 -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 121
전체 시간: 18,230
