주요 콘텐츠로 건너뛰기
Sega Master System II Motherboard Replacement
필요한 것
  1. Sega Master System II Motherboard Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
    • Flip the console on its back and unscrew the 5 screws marked on this photo.
  2. Sega Master System II Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Once you've unscrewed those 5 screws, flip the console upright again.
  3. Sega Master System II Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Sega Master System II Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Once the console is upright, first gently pull the rear of the top up.
    • After the top is at an angle, gently remove it by pulling upwards.
    • Note: Be very careful! The top has 2 tabs connecting it with the bottom half, those are in the vincinity of the 2 controller ports! (marked yellow)
  4. Sega Master System II Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Once the 2 halves are separated, it should look something like this.
  5. Sega Master System II Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Next step is the removal of the RF shield.
    • There are 7 screws in total, please unscrew those.
    • The blue marked screw is shorten than the other 6 screws, this screw has to be put back in the exact same location during reassembly.
    • Note: Tab marked in yellow!
  6. Sega Master System II Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully lift the RF shield up, left side first.
    • See the note in the previous step.
  7. Sega Master System II Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Sega Master System II Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Now we have a complete view of the motherboard, thus coming to the last step.
    • For this step you only need to remove 3 remaining screws.
    • 2 screws on the connector.
    • There's 1 shorter screw as previously with the RF shield. This small screw keeps the voltage regulator in place.
  8. Sega Master System II Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • When you've disassembled everything, it should look like this.
    • Once you've got the replacement board, just follow this guide in reverse order.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Arjan Kuiper
회원 가입일: 04/20/16
290 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 64
전체 시간: 5,052
