주요 콘텐츠로 건너뛰기
Sega Master System Model 2 Disassembly
필요한 것
동영상 개요
  1. Sega Master System Model 2 Disassembly, The Case: 1 단계, 이미지 1/1
    • Take out the 5 screws at the bottom
  2. Sega Master System Model 2 Disassembly, RF Shield: 2 단계, 이미지 1/1
    • Remove the 5 screws (3 at the back and 2 on the front)
    • Remove the screw at the side (this screws is different then the other 5 so remember to put them away from the other 5 screws since they are similar)
    • This screw is for the rf shield under for the voltage regulator under this bigger rf shield, its not needed to remove that screw
  3. Sega Master System Model 2 Disassembly, Cartridge Slot: 3 단계, 이미지 1/1
    • Remove the 2 screws thats holding the cartridge slot down
  4. Sega Master System Model 2 Disassembly, The End: 4 단계, 이미지 1/1
    • Congratulations! You have opened your Sega Master System Model 2!
결론
Screenshots taken from a video by Global Garage
다른 3명이 해당 안내서를 완성하였습니다.
Krisow
회원 가입일: 10/18/17
605 평판
안내서 2개 작성하였습니다
댓글 3개
This is in the wrong section.
Owen Ready - 답글
Nope, its in the Sega Master System area.
Krisow -
Not a Master System
Chad Luciano - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 41
전체 시간: 2,329
