주요 콘텐츠로 건너뛰기
Sega Saturn Power Supply Replacement
필요한 것
  1. Sega Saturn Power Supply Replacement, Battery: 1 단계, 이미지 1/2 Sega Saturn Power Supply Replacement, Battery: 1 단계, 이미지 2/2
    • Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
  2. Sega Saturn Power Supply Replacement: 2 단계, 이미지 1/3 Sega Saturn Power Supply Replacement: 2 단계, 이미지 2/3 Sega Saturn Power Supply Replacement: 2 단계, 이미지 3/3
    • Push up the edge of the battery with the iFixit opening tool to get the battery out of its socket.
  3. Sega Saturn Power Supply Replacement: 3 단계, 이미지 1/3 Sega Saturn Power Supply Replacement: 3 단계, 이미지 2/3 Sega Saturn Power Supply Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the ESD safe tweezers to pull the battery out of its slot.
  4. Sega Saturn Power Supply Replacement, Case: 4 단계, 이미지 1/3 Sega Saturn Power Supply Replacement, Case: 4 단계, 이미지 2/3 Sega Saturn Power Supply Replacement, Case: 4 단계, 이미지 3/3
    • Remove the five black 13.5mm JIS#1 screws on the bottom of the device. One might be hidden by a sticker.
  5. Sega Saturn Power Supply Replacement: 5 단계, 이미지 1/3 Sega Saturn Power Supply Replacement: 5 단계, 이미지 2/3 Sega Saturn Power Supply Replacement: 5 단계, 이미지 3/3
    • Flip the device over so it rests right side up.
    • Lift gently across the seam of the Sega Saturn. If parts get stuck, a light shake or prying with the iFixit opening tool should free it up. Do not use any brute force, as this can damage the case so it doesn't close again.
  6. Sega Saturn Power Supply Replacement, Power Supply: 6 단계, 이미지 1/2 Sega Saturn Power Supply Replacement, Power Supply: 6 단계, 이미지 2/2
    • Unplug the power button plug on the power supply board. Use the iFixit opening tool if necessary.
  7. Sega Saturn Power Supply Replacement: 7 단계, 이미지 1/3 Sega Saturn Power Supply Replacement: 7 단계, 이미지 2/3 Sega Saturn Power Supply Replacement: 7 단계, 이미지 3/3
    • Remove the two black 11.4mm standoff screws on the back of the Sega Saturn holding the power socket in place. These screws are tight and easily stripped, so it's suggested to use a standoff screw head.
  8. Sega Saturn Power Supply Replacement: 8 단계, 이미지 1/2 Sega Saturn Power Supply Replacement: 8 단계, 이미지 2/2
    • Remove the metallic 12.3mm JIS#1 screw holding down the power supply board.
  9. Sega Saturn Power Supply Replacement: 9 단계, 이미지 1/3 Sega Saturn Power Supply Replacement: 9 단계, 이미지 2/3 Sega Saturn Power Supply Replacement: 9 단계, 이미지 3/3
    • Lift the power supply board out of its socket, minding the pins that connect it to the motherboard. Some force will be required, but be careful when lifting or shaking the power supply board out.
결론
Jan Ulloa
회원 가입일: 10/15/19
630 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G6, Leahy Fall 2019 USF Tampa, Team S1-G6, Leahy Fall 2019 회원
USFT-LEAHY-F19S1G6
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 27
30일 전: 147
전체 시간: 4,789
