소개
With use and over time, electric batteries degrade (loss of power/strength and capacity). This guide will show you how to replace the battery of your Segway Ninebot Max Scooter, allowing you to go the intended speed and distance instead of using the degraded battery, which would only get you approximately 50-75% of the intended power
필요한 것
Flip the scooter upside down and unscrew the 18 screws holding the base plate using a Security Torx T15 screwdriver.
Unscrew the 10 screws that hold the battery onto the frame and remove the battery from the enclosure.
Unplug any connectors that connect the battery and scooter together.
Place the new battery inside the enclosure and reinstall the 10 screws (if needed), bonding the battery to the scooter.
Turn on the scooter and accelerate to make sure there are no errors and the scooter is running.
Line up the base plate and tighten it with all 18 screws using a Security Torx T15 Allen Key.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 5개
Do you know where I can purchase a replacement battery for the Ninebot Max? I can't seem to find one.
Chip Bates - 답글
If you find a new battery will you put me onto it aswell I need one do you know how much they are thanks in advance
Do you guys recommend purchasing any brand battery charger for your Ninebot Segway Scooter 🛴 or should I stick with the actual "Segway" brand charger from their official site??? Is there really a difference or is one just as good as the other???
Am o problema, când bateria trotinete ajunge la jumate se oprește, un răspuns va rog!
