소개
Use this guide to replace the Bluetooth remote control of a Hoverboard.
Be careful! A soldering iron is used in this guide, so take the necessary precautions before starting
필요한 것
Remove the 10 screws with a Phillips screwdriver to access the inside of the hoverboard.
The electronic circuit boards are mirrored on both sides, so examine them both to determine which has the Bluetooth setup.
To reassemble your device, Follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 4개
Hello! Would it be possible to know where to get that bluetooth module? I would like to try that one my hoverboard but cant find the needed part.
Ciao,puoi cercare su EBay AliExpress Wish ed altri store cinesi
Smilzo -
Well after 5 days of search on ali.. ebay.. bangood.. amazon. I still haven't found the good part.
I've ask a lots of sellers and they all replied the module they sell is only for music no app control :(
Nix Mathy devi cercare bene come parola chiave.io li vedo su tanti store
telecomando self balance hoverboard
Smilzo -
