소개
If the headband pad or cushion on your Sennheiser HD 4.50 headphones are worn down or damaged, use this guide for instructions on replacing it. In order to complete this repair, you will need to buy a new headband pad to replace the defective one you are removing.
필요한 것
Extend the headphones by pulling the headband away from the base of the headphones.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Is there any guide on replacing the hinge that the ear cups are connected to?
